disable bgp community format
disable bgp community format AS-number : number
Description
Disables the AS-number:number format of display for communities in the output of show commands.
Syntax Description
Default
Disabled.
Usage Guidelines
Using this command, communities are displayed as a single decimal value.
The following command disables the AS-number:number format of display for communities:
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
